Kelly in tx
old, you've often recommended filling the valve train and cylinders with ATF. I put 8 quarts of ATF into my 1963 6 cyl IHC truck today. It has been sitting for about 20 years and the engine is stuck. I also dropped the pan and put a floor jack with a pipe under the front rod (still connected to the crank) and I applied some pressure.
How much ATF do I need to use? As I said, it is a 6 cyl engine. It says 150 gross hp and 130 net and has overhead valves.
Any other suggestions? Thanks, Kelly P.S. The other day I teased you about my Farmall 460 engine. Would that engine fit into the truck?
