MMoline Z water pump and fan belt #
My model Z Moline had a Napa belt on it which to me seem to small as the belt was tight and fan would barley clear edge of radiator shields. The number on the Napa belt is: 25-9447 is this the correct belt and if not what is the correct belt number?
if its sitting to the top of the pulley grooves, then it may be just too short or too long.you did not specify if too close to top or bottom. easy fix... take old belt to napa and have them measure it then order accordingly. the parts mans job to get correct belt.
Rustred, it is to close to bottom there is not even any give if u push in on belt. Reason i was wondering if the old belt i had was not correct?
Well, now there are 2 MM Z engines. The RE and the 206B. Which do you have? I'm pretty sure it makes a difference which belt you need. Or at least it depends on which fan is on the engine you have.
You need to post down on the Minneapolis-Moline forum.
