Eldon (WA)
Well I hear Big Tex bought out PJ. I hope they don't cheapen up their trailers to match the BT. I sold my 07 PJ 14k dump and bought a new Big Tex 14K last December thinking they were pretty much a clone of a PJ...wrong. The Big Tex is pretty flimsy, the PJ had a horizontal channel running down the sides where the BT does not. May not be a big deal, but it rattles a lot more when empty. The BT takes a lot longer to dump, I think they went to a smaller pump. I was able to put a bigger battery in the PJ to increase battery capacity and cycle time, BT has the pump crowded close to the battery, so will have to move the pump if I want a bigger battery. The ramps on the BT are narrower and shorter! I feel like I am going to spin out loading my 6500# skidsteer....can't wait to do it in the rain :x Then when I get in the box with it it pops and creaks like something is flexing the wrong way. The doors for the ramps don't shut tight, so whenever I dump a load of gravel they fill up and I have to take the time to clean them out. Also the rear tie-downs are on the floor of the trailer, so whatever I am dumping gets hung up on them and more time to clean. The license plate position would have had the plate hanging below the frame (come on guys, it's a dump trailer and the frame dang near drags on the ground when you dump)....great engineering. I finally bent the handle that locks the swinging gates in the rear as you would smash your fingers every time you closed them. I almost lost the pivot pins that hold the tailgate on as they forgot to put cotter keys in them. The good? It has a 110 charge port, spare tire mount on the side and came with a roll over net cover that actually hooks on the rear.
Overall, I am disappointed...I expected more from a major manufacturer. Oh, and I finally got my $300 rebate from them after 5 months of waiting. Will have an update later on the 25 foot 14GN deckover that I also bought at the same time.
