Richard G.
I have a front axle from a 52 Ford 3/4 ton truck that I am modifying to use under a wood wagon I am building. It is very heavy. It will be the front axle that steers. I am welding different spindles on it and need to shorten it a bit. Also will weld a center swivel pin holder so it can pivot up and down. It is a drop forged axle. Hardest metal I have ever tried to cut. Wears out sawzall blades and grinding wheels. What type rod should I use when welding on it?
My thoughts are 7018. Been welding for over 55 years and never found anything as hard as this.
Thanks, Richard
Thanks, Richard
