I had to replace the head gasket on my skidsteer last fall. I finally got around to putting it back together today. I had the injectors pressure tested and one was bad. The bad one was on number 3 cyl and it was where he head gasket was bad also. When I took in apart I saw what I thought was a big build up of carbon in that cyl. Well yesterday I went to clean it out and it was not carbon. It was a big blob of casting material blocking about 3/4 ot the hole in the manifold. I put it in my mill and cut all most 1 inch of metal out of it. I bet it will run better
Ivan in the exhaust or intake.. Done a lot of KUBOTAS and never heard of this. Are you sure the piston is good in this hole?
