Ot 1992 F700 front rotor
ffreeb
I have a 1992 F700 4 wheel drive farm truck. One of the front rotors is cracked. New parts are no longer available. There are a lot of people with a great deal of knowledge on this forum. I'm hoping someone can help me find one. NOS, used, any I can find.
I just checked, they don't have one that matches mine. The 4WD
makes it hard to find. Thank you just the same.
i would do some research to see if that front axle was used on other trucks. id also check with an aftermarket truck supplier, if there are casting numbers on the rotor they may be able to find one
Get the original Ford part number from your Ford dealership parts man and start entering that number into Google.
You can also try greensalescompany.com, a site that specializes in obsolete Ford parts.
There's got to be one at a salvage yard somewhere, also.
A lot of bucket trucks and auger crane trucks use that front axle. Ford didn't build the axle or the transfer case. You need to find out who built the axle and who made the brake system for the axle. Chances are they still use the same brakes on several brands of trucks and they would all have different part numbers. I don't know what part of the country you live in but here in Indiana there are several major brake parts houses. Midwest brake (317-632-4787) and Power Train (800-999-3912) can help once you identify the axle. Hope this helps, John
It's a Rockwell fds-75 axle with a Gunite D6113 rotor. Gunite says they only made them for Rockwell and they haven't made them since Rockwell last ordered them. I'm hoping someone might know where I might find a NOS one or a junk truck is setting. Thank you to all that replied and I will check the places suggested.
Try B&W Truck parts.573-393-2357. They scrape a lot of trucks and just might have one. Taylor MO.
