Rkh
What is the dosage water to rodon? Using on some tree limb like that crawling up fence that makes difficult to mow. There's instructions, but no ratio to water, unless use straight
cant remember but it is similar to Sendero what I spray for mesquite down here use 2 oz. per gallon with a surfactant.
I use it undiluted to ring the stumps of newly cut trees to prevent regrowth.
Not sure how effective it is if sprayed....
Dean
The quart bottles come with a diffusion tip on the top. I've always just used that to apply full strength directly to a freshly cut stump.
RTU stands for ready to use. No water to add.
The bulk farmer jugs would get mixed with water and other stuff, as per the label on those.
RTU is already pre mixed for you.
Paul
As the others stated RTU is ready to use. Spray liberally on open fresh cuts and there will be no regrowth. It will also kill a tree if sprayed on open cuts when pruning. Stuff works great on mulberry here.
jt
If spraying a fence you might try Cross Bow, wont hurt anything but the woody plants. Spraying Tordon like that will get a might pricey.
