Erickson Cl 30
pirateDale
New User
I have an Erickson CL30 skid steer. I need a wiring and hydraulic diagram. Any help would be great. Trying to get the thing running and I have wires I don't know where they go. There is one wire coming from the hydraulic filter housing. It looks like it may be a pressure switch or temp switch. I have no idea where to land it. Thanks
I can't help much but should be very nearly the same as Ford CL30.
Gehl HL3030 is less similar in the hydraulics and has drum brakes on the front.
Internet says new axles are available from machine shop in MN. Good luck!
It is pretty much the same. I'm just looking for some diagrams. I have most everything hooked up. Had to rewire the whole machine. I have ordered a manual for the CL30 and hope it has what I need.
My HL3030 has a pressure gauge mounted to the filter housing. It reads in the red zone starting about 35 lbs. Could it be you have or did have a pressure gauge on the so called dash board run by that sender.
