Starter removal Ford 1710
flembo
Will I need to remove the hydraulic pump or maybe just the 1" blue supply line to get it out, it looks pretty close.I am hoping someone here has done done it before, I posted this on the Ford sight also. I am including a couple pictures. Well I can't find the second picture.
I have done some kinda like that. The starter nose was short enough to come out. With a little twisting to one side.
Thanks Billy the good news is I charged the battery for 2 hrs and cleaned all connections and it started fine. I suspected the starter because I tested the battery with my battery/ charging system tester and it showed to be fine. I guess brite and tite was the secret. Thanks again.
Most of my no start service calls. Were because the batteries were dead or dirty.A good clean connection will solve allot of problems.
Shouldn't need to remove anything but the starter and cables... It should twist and pull out. I'd try that first before bothering with lines anyway.
Rod
