Company Logo (800) 853-2651 Shop Now
Tractor Talk Discussion Forum
What to use to clean up faded tractor?
tomstractorsandtoys
03-21-2017 13:28:55
I just bought a 4020 that the paint is very oxidized and was wondering what you would recommend to clean it up? I understand that nothing will bring back to original but there must be something to clean it up some. There is like a dark cast to the paint. I did try a rag and some PB blaster and that helped some. I might buy a small buffer. Any ideas? Thanks Tom
Dan Richardson
03-23-2017 02:51:41
 Re: What to use to clean up faded tractor? in reply to tomstractorsandtoys, 03-21-2017 13:28:55
A red brick and coal oil.
SVcummins
03-23-2017 00:20:33
third party image
third party image
Here's what mine looked like 15 year old sometimes wash it once a year sometimes not .polished it with turtle wax metal polish
showcrop
03-22-2017 04:34:51
Like SS55 and Rusty6 say, rubbing compound. I keep have kept Dupont red and white on hand for forty years.
D beatty
03-21-2017 21:07:04
third party image
I use Nu-Finish on my vehicles and tractor and works well and doesn't scratch.
Brown Swiss
03-21-2017 19:49:22
I don't have an answer for your paint renewal, was wondering if you seen how much the bale grinders went for? I left when Jeff was selling the Meyers spreader after the McCormick tractor on the outside row.
rusty6
03-21-2017 19:01:55
I'll give another vote for rubbing compound. You might be amazed just how good the paint is once you get the layer of oxidized paint and dirt off. I only work by hand with rags, no power tools. That way I can tell better just how far into the paint I'm getting. Where its really bad I'll even use fine steel wool and diesel fuel. Just look at the shine on the original paint on my old Merc after 40 years sitting in the bush. It is right down to red primer on the roof but its got a dull shine to it. Coat of wax to protect it and indoor storage it will be looking good for years. third party image
M w J
03-21-2017 18:37:08
comet works well on a wet rag and put the comet on the rag.
ss55
03-21-2017 17:16:56
Rubbing compounds work the best. They are abrasives that revitalize paint by removing the oxidized layer of paint. They work best on newer paint where the lower paint is still in good condition. Old worn-thin paint could be oxidized all the way through. Be careful using power tools with an abrasive as you can get to bare metal in a few seconds. I would ask what the dealers use, some auctioneers wipe down sheet metal with diesel fuel to make it look a little more glossy.
mattwillson
03-21-2017 16:55:58
ATF or lemon pledge, future floor wax as well..... don't expect more than a couple months though..
300jk
03-21-2017 15:48:46
When I bought my Kubota b8200 it was faded some. I used meguiars scratch x. Worked ok. I actually used mother's mag and aluminum polish. Seemed to cut the oxidation better. Lots of rubbing. Maybe a polishing compound and buffer would work better on a big project.
fbh44
03-21-2017 15:33:43
first thing, I'd go to car wash, set it on High-Hot, and blast away, for a good long time.
Crazy Horse
03-21-2017 14:08:15
Super fine grade rubbing compound ..... followed by a good quality car wax?
JerryS
03-21-2017 13:52:31
Rustoleum sells a color restorer that works beautifully in their TV ads. Don't know how it works in Realville.
rla
03-21-2017 13:50:11
Comet cleanser in a bucket when U wash it.. Then depends how bad the paint is rubbing compound different grades & a Buffer . Too much buffing you'll go threw the paint , watch the sharp edges, it will brighten it up then Wax it... Will hold for awhile.. Keep indoors helps too.
WAYNE-N-TX
03-21-2017 17:34:51
 Re: What to use to clean up faded tractor? in reply to rla, 03-21-2017 13:50:11
Add this to the comet, dish washing soap (liquid) and bleach. Use a medium soft brush, works wonders.
smalltowner
03-21-2017 13:50:01
Meguiar's Ultimate compound color and clarity restorer works pretty good and not expensive. I've only used it on red, nothing green around here. It takes some elbow grease but does the job and is not harsh like some of the body shop professional products and is clear coat safe. I did a '98 Ford pick-up last year and it did a great job. They recommend waxing after completion.
Janicholson
03-21-2017 14:28:07
 Re: What to use to clean up faded tractor? in reply to smalltowner, 03-21-2017 13:50:01
Fully agree. It works well. If it has been clear coated after fading (or before) it might not do much. The green needs to be the surface that any one of the tactics works on. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
Latest Ad: IH model 8 Little Genius 2-12 rope trip plow on rubber. Plow is field ready. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
