No , however I have found the holes in both my trailers have holes that line up perfectly with the same license plate. That enables me to only buy one plate. After a bit of grinding thankfully now the ID numbers are the same on both trailers. Life is good, at least till I get caught!!! I know if my mother were still alive she would call me a common criminal just like when I got my drivers license revoked when 17.
Not to hyjack you post but. Does your state require an inspection for trailers? In Texas any trailer over 4'000 gvw must be inspected by a DOT certified inspector. But I see lots of them on the highway that look like they just came out of salvage.
No trailer inspection in Ohio that I'm aware of. I have a 14K equipment trailer registered commercial - would let you register it either way and I think commecial was slightly cheaper or something.
I live in Ohio, a college town. It seems when I read the local blotter improper vehicle registration and license plate violations show up fairly often.
I just bought a trailer three months ago had it weighted took weight slip to DMV there questions were is it home made (if you don't have a title answer that yes even if it is not) and what county do you live in(for tax purposes) I think it was around fifty dollars. It is a non commercial trailer. hope this helps John
willson at least you put a plate on, got a 16' landscape trailer and a 12' single axle alum trailer[pull the gator on] havent taged these trailers in 5 years. got caught two years ago, fine was 50.00 dollars and a slap on the back of the wrist, dont do it again.....still dont have tags
(quoted from post at 18:28:38 03/20/17) anyone know how much plates will cost for a trl. weighing 3600 pounds in ohio.....
Does the trailer weigh 3600 lbs, is the GVWR 3600 lbs or are you going to try and register it for 3600lbs? In any event, your state DMV will have the answer on cost.
