Rod bolt torque
37chief
Location
California
My manual doesn't give me any torque specifications for my A/C Model M. What would be a torque I can use for 1/2 inch rod bolts? Also the head has no torque specifications for 1/2 inch nuts. Any suggestions? Stan
My book does not call out the model M but references Allis Chalmers torque on 1/2" engine nuts as 70 foot pounds.
Given how critical connecting rods bolts are and the chances that some Bubba in the past has stretched them while guessing instead of using a torque wrench. This would be the time to consider new bolts.
Torque specs for a 1/2" grade 5 bolt would be in the ballpark.
Hello 37chief,
For 1/2" grade 5 I would use 75#.
For grade 6&7 I would use 85#
For grade 8 I would use 105#
Remember these values are for dry clean threads. If you lube them you need to reduce your final torgue 10%
Guido.
