John Achmann
Got a 1250 bearcat grinder mixer in my shop to look over for a buddy of mine. The mill works great but got a couple questions on it. We don't have an owners manual for it and can't seem to locate one. The first question I have is the big auger inside is supported on top with a bearing that has a lock collar. Now the auger is down to where the collar won't lock on the shaft. So what would cause the auger to be to low? The gear box underneath looks to be good and not out of place. I've worked on other mixers that have a bearing on the bottom that also supports the auger. I haven't pulled down the gear box to see what it looks like under there. The other question is does the gearbox take 80-90? When I pulled the plug it looked like corn head grease in there. If some one has a operators manual or a parts manual that I could get some information from I'd appreciate it. Thanks for any help.
