Replace teeth on spring tooth harrow- need advice
jacks
Looking for any advice on where to find replacement tines for an Oliver model 200 spring tooth Harrow manufactured by Brillion. The tine is 3/8 thick one and three quarter inches wide and about 21 inches in overall height. Looked on Sloan Parts but can't find a similar one. Or, could I change them all to a different style tooth?
Thanks for the suggestion. Since I don't know the brillion model number it may be tough but I will try calling Messicks in PA.
Some of the teeth are broken, others are worn so badly that the holes to bolt on a point are not there any more. I will have to replace all the teeth due to the worn out condition.
Oh, you just want the shovel point.
That uses to be stocked in the fleet and tp farm stores here a decade ago. I've gone to stuff that uses 9 inch shovels now, but I would think Weis and other such generic tillage suppliers would still offer them. The point comes with a round hole and a slotted hole so it fits several bolt spacings, what is the bolt size and spacing between them?
Paul
I'm thinking that John Deere had a similar harrow, perhaps even built by Brillion. I have no idea of the model numbers, but those tines look similar.
The bolt-on teeth may be available aftermarket from manufacturers such as Nichols or Wiese.
AG
i know you don't have them but our Fleet Farms have new points.tractor supply might or rural king or any dealer should .take a old one off and match it up hole spacing is the only thing that has to line up. if you need spring shank then dealer will be your best shot
Sorry, I spelled the name wrong.
I think the bottom one on the list is a likely candidate.
Depending where you are a Fleet and Farm store should have them or could get them.
Paul
I believe that is a universal tooth. Any unit that the teeth mount on a channel iron bar will be same and work. just about two types ever made, the type you have and the type for a pipe bar harrow. I would think J D would have them but they will cost way more than your unit will ever be worth.
Thanks for the replies and suggestions. A replacement from Brillion is about 70$ or more each. Looks like I need to find used parts or maybe a universal tine.
