I put 2 new John Deere batteries in the JD 2755 along with new battery cables. Ran tractor for about 2 hours and one battery boiled over spilling acid down the side of the tractor. I checked the alternator's running voltage which was 3.8 volts. Took the one battery back to John Deere and they tell me there is nothing wrong with the battery. I did check to see if any cells were over filled and all were exactly the same. So what am I missing? I figured if only one battery is boiling over, it must be that battery or both would be boiling. If the alternator for some reason was over charging for a short time, both batteries would be over charging and both would boil. Why is only one battery boiling over?
