Gresen hydraulic spool adding float
Bkpigs
I have a 2 spool Gresen valve block mounted on my IH504 for the loader but it does not have float position on either valves. Is there a way to add that or should I find another valve block?
Here is a picture of float valve, Jim
In My parts that is called a DIVERTER valve, changes the flow and I guess it could be plumbed to open and cause the loader to float but most float valves have an extended spool with detents to hold the spool in float position. Think you would be much better off just getting another valve.
Gresen makes a diverter valve that looks like my float valve but is just not the same. Pulling the knob lets the loader drop and float, but you have to push knob back in to raise loader with loader valve.
You have a casting number? The valves with float have a longer spool. I think I have one left I would part with cheap like.
2702 is on the top. I have another spool block that does have float but it is not pretty. Just wanting to know if it was possible to add float to the book itself.
