Slow-mo video of visible combustion chamber
denglish
Some of you might like this video. Nothing new with visible engine, but this guy has a 4000 frame per second camera which makes for some cool footage.
https://www.youtube.com/watch?v=Jjz-EIh0gPw
(quoted from post at 10:25:00 01/25/17) That IS pretty cool. gm
The video after that one is pretty interesting too. He runs the motor on rubbing alcohol and you can see it sloshing around in the combustion chamber. Pretty crude, but interesting.
You can see from this video why an "overhead" valve engine is more efficient as all the "fire" over the flat head valves doesn't do much
for pushing the piston down. Also double overhead spark plugs are more efficient at high speed because the fire has to happen so
suddenly!
I would have never thought liquid alcohol (and water) would have ever run!
That little motor just wants to run whatever it is fed! LOL
I was suprised how much it sound's like an alcohol dragster. I always figured they sound that way because of high compression and cam grind. Can't wait to watch with the 12 year old grandson.
