Water displacement 40 to the rescue
Bruce from Can.
Lock on the fuel tank was frozen, and I couldn't even get the key in. Today was just above freezing, so I thought , today's the day. Key went in , but wouldn't trun . Went and got my trusty can of WD40 and gave the lock a few shots up the key hole. Presto! Opened right up. Now my question for the brain trust is , will this keep the lock from freezing the next time it turns cold? Bruce
The dried silicone residue may do some lubricating and displace some incoming water. To lubricate a lock, I prefer to dip the end of the key in motor oil and then open the lock with the key a few times to distribute the oil. On padlocks, drip some motor oil on each side of the shackle and cycle the lock a few times.
I used to work at a place where every day this guy went out to one of the trailers we had for storage. In the winter the lock was always frozen so he would pour a cup of hot water in it to thaw it out. Never could figure out why the lock would be frozen again the next morning even if it didn't rain.
The trunk lock on my car was froze up, or maybe it was rusted shut. I used PB Blaster and after a week of trying it, it opened. I have not had anymore trouble with it.
Hello fredstef,
Propane torch or cigarette lighter. If its frozen warm the key two or three times if necessary. Melt that
rascal to open every time!
Guido.
I theory it should work for a while up till the WD40 has dried up and a lot of water gets back in. Of course many things come into play will does the lock sit in such a way that rain/snow can and will go into the key slot easily or does it sit so the slot faces down ?
Common occurance in the electric utility business. We never used any oil based lubricant in locks as the residual attracted dust which clogged up the tumblers. We kept those long propane lighters on the crew trucks to quickly thaw out locks.
Bruce,there is a product called Lock Eze (sp?) that is graphite based and it works real well.The WD40 will probably work ok tho,but Lock EZe,or Ease, is the best thing I've used.Auto parts houses should carry it.Mark
I got a lock that will freeze up in the cold. I cup my hands around it for a minute or so and that will thaw it out most of the time.
If that elec pump is 110 volt, borrow the hair dryer from your better half....safer than a torch. My son used a hair dryer to free the dog when gonads were frozen to the ground. Now, that"s a whole other story!
Check with your local locksmith. Mine says WD40 no good, eventually gums up the tumblers. He recommends some other lube that doesn't leave a residue, can't remember the name but I bet your local lock guy has something.
(quoted from post at 22:43:03 01/24/17) Check with your local locksmith. Mine says WD40 no good, eventually gums up the tumblers. He recommends some other lube that doesn't leave a residue, can't remember the name but I bet your local lock guy has something.
I use something from the locksmith called 'Houdini'. It is thin as water but works great on locks. Available online, about $15/can, which will last a lifetime. Lowes sells the same product under a different name. Don't have the can handy, will check.
Garry
I don't use WD-40 as a penetrating oil because I feel there are much better products available for that.
However, WD-40 works great for drying out a wet distributor cap.
I've also heard some people still use it to kill leg mites in a flock of infested birds. (Google it)
(quoted from post at 15:01:31 01/24/17) ...................... Now my question for the brain trust is , will this keep the lock from freezing the next time it turns cold? Bruce
Probably not. But what [b:0bb6a60fa4]guido[/b:0bb6a60fa4] said works everytime! [i:0bb6a60fa4]Propane torch or cigarette lighter. If its frozen warm the key two or three times if necessary. Melt that
[/i:0bb6a60fa4] 8)
I (under protest) have to take SWMBO's dogs out from time to time and the big girl loves wallowing in snow.
Often, once back inside the snap on her lead is frozen preventing her from being disengaged from it so I can return to napping in the recliner.
I simply wrap my (cold) hand around the snap and within a half-minute or less the snap unthaws, no magic jizz involved.
Mite work on a small keyed lock, as well.
YAMMV!
(quoted from post at 03:20:24 01/25/17) If that elec pump is 110 volt, borrow the hair dryer from your better half....safer than a torch. My son used a hair dryer to free the dog when gonads were frozen to the ground. Now, that"s a whole other story!
You have my attention!! I have got to hear this one!
You are exactly right. The "wet" lubricants and de-icers are only a temporary solution. The problem will only come back worse next time, until it gets so bad you have to cut the lock off.
Dry graphite ONLY in locks. I fought with the padlocks on my trailer for years. They'd get hard to open, I'd squirt 'em, they'd work for a while, I'd squirt 'em, they'd work for less time, I'd squirt 'em, they'd work for even less time, I'd squirt 'em, then they wouldn't work at all, so I'd have to throw them out and get new locks. The last set of locks has only been lubed with powdered graphite, and they've lasted longer than all the other sets combined.
I just take the lock off mine in the winter. Other than me, there are not a lot of thieves that use diesel fuel.
