I want to build a new pto shaft for the 3 pt blower I have. I thought I had a good idea which was cutting both ends off the hollow tube that I have which is kinked and re welding the ends on. The pipe I have would sleeve over both ends of the existing tube after I cut it to length. I thought that would work well sliding the new pieces over the existing tube cause it would help keep it square. Just talked to a friend who told me no way. He said I would never get it square enough and will take out the u joints. I have welded shafts together before using angle iron to keep them lined up. Is this so much different ? Am I missing something ?
