(quoted from post at 12:23:05 12/23/16) When I had a tile chimney, The chimney sweep chemicals would keep the creosote deposits dry, crumbly and greyish colored and very easy to clean out. If I didn't use the stuff the creosote was much worse and harder to brush out. I have the triple wall SS pipe now and I use the chimney sweep packets about once every two weeks. At the end of the heating season, I have about a quart of dry grey ashes in the two elbows combined. Running a brush down the pipe produces almost nothing. They won't keep a chimney clean to the point you don't have to brush the chimney, but in my experience they help keep the creosote converted to dry grey ash. [b:79f84f9f3f]I've also seen chimneys that the stuff was no help at all in. All you can do is try it in your setup and see if it helps or not.[/b:79f84f9f3f]
