johnarlyce
New User
I have new starter push-button switch. New one wire alternator that has two white wires running from alt. to starter pull-out switch, etc. New 12-volt coil. It appears that something is drawing the battery strength down swiftly when trying to start the tractor. 650 CCA battery. Do you have a step-by-step procedure that could help me pin point the problem better? I replaced the original coil because I wasn't getting spark from the plugs. I haven't rechecked yet. Gas flows heavily from carb when I first open line. I admit it does need to be looked at also. I just can't figure out what is wrong. Super C was converted to a 12 system before i bought it. Maybe some things can't be introduced with the old system parts. Any help would be greatly appreciated.
