have a 1951 Ferguson TO-20. the problem is the loping or jerking when it is being driven. gets worse when up start up hill of pull.
Does it in all gears. including reverse.
govener does not move nor does the engine appear to rev up or down.
do not think it is gear related because if it was once the gear lag would tighten it should be smooth. Gets worse with higher rpm.
in fourth gear going up hill it almost bounces the front tires off the ground.[/u]
