Block Heater 580E
(quoted from post at 10:22:52 12/16/16) I picked up a block heater for my Case 580E backhoe (which I should have done in September) I assume it goes in the freeze plug opening near the starter. Am I right?
Thanks
Pete
That will work.
Ideally you want it close to center of block the better.
Just make sure the elements are oriented proper as not to
Touch the block or Cylinder wall. Usually pointed down.
TP
Pete, My White has the same engine and that's where the mechanic from Sharon Springs Garage put it. It's always started good just make sure its plugged in for a couple hours works the best.
