Ford 3000 high engine oil pressure
If you oil too is thick at startup, you could switch to a winter viscosity oil, like a 10W-40, 5W-30 or 0W-30. Check the owner's manual for what the manufacturer recommends in your winter temperatures.
Is that warm or cold, rebuilt my 4000SU a couple years ago with new oil pump, this summer at idle the oil light flickered so I put a gauge on to check actual pressure.
With 15w40 Delo it has 75 psi cold and 35-40 at low idle (600 rpm) hot, with 100 hrs on the oil.
