Vickers V-10 Hydraulic Pump
Rkh
Found a used vickers v10 pump serial number v101p6y27b20. I know there's a website that explains each number/letter on the serial number, but can't find it. Would like to know the gpm this pump puts out.
Hello rkh,
I have a Vickers spec book. I will dig it out, its in the COLD garage. They are reversible if you need to change the direction. Also the presure regulating valve can be changed to alter pressure,
Guido.
The 6 between the p and y.says it's 6 gpm at 1200rpm. Because their is nothing after the 20, that means it's clockwise rotation
looking from the shaft end.
Hello Rkh,
here are the numbers for you. 6 gallons per minute @ 1200R.P.M.'s CW rotation looking at the shaft. I have more info if you need it. The center portion of the pump has an arrow which is the direction of the pump. That is the part of the pump you can reverse for opposite direction operation,
Guido.
