rusty6
- Location
- East central Sask.
For several winters now it has been really hard to get this reddy heater to ignite when it gets cold. Like below 0F degrees. The only way I could get it to light was by unscrewing the top cover and opening it up. Then it fires up instantly but burns pretty rich with a flame as I guess there is insufficient air to the nozzle without the hood. Set the hood back on and try it again and it fires right up fine. I can use it this way but its a nuisance having to unscrew the cover every time to fire it up. I've tried air pressure adjustments but it was not the real fix. Talked to a guy with an older John Deere heater that has the same problem.
