big tee
It has been talked about on this site and others so I thought I would try it. That is putting a pipe over the cutting edge of your snow pusher. I bought a bigger bucket for my loader last year with a very sharp cutting edge and there was no frost in the ground and I had rerocked my yard with bigger crushed lime stone so I sometimes got more rock than snow. I had 1.25 and 2 in. ID pipe so I was not sure which one to use so I cut a short chunk of the 2 in. and split it with the chopsaw and slid it over the cutting edge to see how it looked. Looked good so never even tried the smaller pipe. Used my plasma cutter and a piece of angle iron for a straight edge and took about 3/4 of an in. out of the pipe. Had the bucket standing on edge but couldn't keep the clamps from slipping off until I put the forklift on it for weight. Used tabs on both sides with 3/8's bolts with 3/4 in. nuts for spacers. Had to use what I call "my Polish drill press" to drill the holes to hold it on. Used it today and it works 10 times better than I thought it would---level the bucket and put the loader in float. So thanks to you GOOd people that showed me the way.---Tee
