Looking for a front balancer for a 300 Cummins
LeakyBoot
1987 model 855 cubic 300 HP. Has the 2 groove v belt pully on back. Any leads on a salvage with 30 yr old parts? Thanks, LB
Caledonia Diesel: 585.538.4395 Have the engine CPL number (on the nameplate) when you call.
You must have priced a new one already, they are spendy. There's an aluminum pilot that centers the pulley and damper on the crank . It's reasonable enough in price and should be replaced as it will deteriorate and cause the works to come loose.
I know this is an older post but I just saw it. The damper should be separate from the pulley. The damper p/n is 4987064. They are available in Salt Lake for about $240.00
