Tractor chain install
Mike Groom
Just helped my 80 year old neighbor install chains,does anyone else pay attention to how the latches face forward or back when installed,I'm 68 and haven't noticed that they have ever unlatched when facing the other way.
I install them so they are less likely to catch obstacles or debris as the wheel rolls forward, so that would mean if the latch is at the bottom, the open or latching end faces forward.
Probably doesn't make a darned bit of difference, and, of course, when you back up the other end becomes the leading edge!
I can't remember ? I do watch for which way the ends of the cross links are. The ends of the crimped links to the outside so as to not have any sharp edges to the inside.
as you are generally moving forward and backward..with a loader. I don't believe it makes much difference. However, I bolt my slack chain across the 'coupling/latch', to guard against the chain falling off the tire. However the best protection from a latch/coupling disengaging is to tighten the chain on the tire. At 75 it can take me an hour to properly install and tighten the chain to the tire... in 40 years of doing it this way I've lost a latch only once... but the slack chain bolting kept the?chain on the tire.
I usually run a piece of black wire through the latch to prevent it from coming undone, and wire down the loose chain as well. Ben
And when they are half worn you flip them over so it doesn't really matter with the cross link hooks!
Put one facing one way and one the other. Let us know in the spring!
If you want to save yourself some work, lay one chain out on the ground outside up behind the tire. Tie a rope to the end and run the rope over top of the tire, and tuck the end under. Drive the tractor forward, with a little repositioning the chain will pull itself around the tire with very little slack and no lifting.
I do similar but a little different.
I jack a tire up and hook the chains onto the lugs on the tire. Then roll the chain up and over the tire.
On my Case skidloader I put the open end of the latches to the back. I don't think it makes any difference,I go backwards alot plus spinning to turn. I wire the latches and hook a couple of bungees to the outside of the chains to take out the slack. Never had any problems.
