A few random pics from today
Adirondack case guy
the uncles are busy combining corn again after the 20" snowfall. Temps have warmed and water is running everywhere. Still a lot of snow in the west sides of the corn fields, and some left in the woods.
Temps made about 47F here today. I started my Case 440 which has sat since finishing firewood in Sept. and took it for a ride thru the sugarbush. Also started my 930 which has sat about as long and ran it a bit also.
I was also able to spray some primer on the tailgate of my new wood trailer.
It is supposed to get into 50s for the next 3 days, but heavy rain predicted. We don't need that.
I sure am glad that I didn't have to dig in my new water line in this slop.
Loren
Ground is about as wet here, sky no where near as blue. Just got thru pulling my neighbors grain semi out of the roadside where he parked it to fill. Semi's full of corn don't pull easy. And still raining.
We had an inch of rain here today in Illinois by St. Louis Mo. How's your new water line doing Loren? John B.
Loren,
Great pictures and fine CASE tractors as always. Tell me about the framework extending forward from your 430 cab.
Thanks,
Glenn F.
Glenn, I mounted a Myers snow plow onto the 440. I decided that a catI 3pt hitch would be handy, when the plow is off, so I built one which just pins to the plow frame and the plow lift operates it.
Loren
John, water is flowing into the house under pressure, so all is good. I sure wouldn't want to run a tractor tire over the backfilled ditch though.
Loren
