I am moving power from above ground to below ground on piece of property. There is a gravel road that belongs to neighbor that I prefer to not dig up. The gravel road is about 20 ft across. I have dug a trench on one side 13 ft long and a 3 ft trench on opposite side. Trench is about 24 inches deep.
I have already had locating company come out to determine where telephone, power and water lines are located. So I am clear of those.
I plan to use a 10 ton ports pier unit to push pipe under road. I wanted to use rigid metal conduit but it was $100+ for a 10 ft section. The plastic conduit is $18 for 10 ft section. So I will try the plastic first
So will put pipe in trench , level it and use ports power to push it through.
No rocks in trench so I think I have clean soil to go through.
Anyone else do this ? Success/failure? Problems?
