(quoted from post at 18:38:53 11/21/16) Finished the Constitution. Working on a 1/25th scale Ford Model A roadster. After that going to my 4 period ships which are 1/65 scale from Artesania Latina, Italian model maker: La Nina, La Pinta, La Santa Maria and the Mayflower.
The Constitution hull was a rough cut block of wood. These are frame and plank construction.
I worked on the C for over 6 months, but that was during the spring/summer/fall. Over the winter, I MIGHT get finished with the Nina....first in the chute.
All will have the ?" Acrylic sheet display cover. The Constitution's dimensions are LWH 29 ? x 12 x 21. Getting that cut and glued together working alone with no bracing is a work in itself, but you have to have it to keep the dust off.
