3 wheelers ?
01gentdc
the massey post below begs a question ,,. certainly certain regions felt the need to have one single front tire,. cultivating comes to mind ,, here in southern ind,. a single front tire tractor is scarcer than hens teeth ,,. and when you do see one it is only at a show. can some of you tell me what applications and jobs were they best appreciated.
My Silver King has a single front, I would say probably 75% as a rough guess were single front. Single front and wide front end, I've never seen one with a dual tire narrow front in person or pictures. The reason for it? I don't know, maybe because it was cheaper to manufacture? It's alleged to top out at 40+ mph, so you would have thought a WFE would have been ideal.
About the only ones around here were on Farmall F12s. My grand dad on my mother's side had one. When I was a kid and asked Dad why they made them that way,he said it turned shorter with a cultivator. I don't know if that's true,or if he was just throwing something out there to satisfy my curiosity.
There used to be a lot of single fronts in the furrow irrigated regions of the west/southwest. Particularly in ares where sugar beets,pinto beans,onions,vegatables... The single front would follow the 'water mark' (furrow),whearas the 'regular' tricycle front would not. The single front tire would also tend to pack the bottom of the mark for better water flow.Singles are very common here,they vastly outnumber the tricycle(dual) front. It's a regional thing. These days,with the bigger tractors,more rows(bigger planters) the single is fadeing. Guys now just use wide front tractors with narrow tires.There are still a few 4020s,806,1080etc with singles still 'floating' around.I know of a 4320 with a single still being used.
A slingle or tricycle front each turn about the same. The do howeven turn way shorter than the wides. often times the single will just push and slide,whearas the tricycle will grab and turn right around cue to more tire on the ground.
That's what I always figured. When I asked him why we didn't have one,he said if you have a flat tire with a two wheeled narrow front,you could still drive it on one wheel,with a single tire you couldn't. I don't think he really had an answer any more than I did,but he had to say something. lol
(quoted from post at 07:40:15 11/20/16) the massey post below begs a question ,,. certainly certain regions felt the need to have one single front tire,. cultivating comes to mind ,, here in southern ind,. a single front tire tractor is scarcer than hens teeth ,,. and when you do see one it is only at a show. can some of you tell me what applications and jobs were they best appreciated.
I collect them, they are something different to look at anyway. I found that they make a good road tractor as they don't get that front end shimmy like the narrow fronts do. JD are pretty plentiful around here, AC are getting scarce. I have 3 C's, a CA, WD, D17 and this WD45 diesel that I put together. The WD and WD45 wide fronts could be easily converted to single fronts.
Those are the tires from that H that you bought from me....and yes, they are not correct for that tractor. I was just making a tractor to cultivate taller corn.
Actually 38" rear wheels could be had from AC factory for the High Clearance model with the single front wheel.Think they were a little narrower than yours but still 38",the WC high clearance
had 36" rears.
(quoted from post at 09:30:10 11/20/16) Actually 38" rear wheels could be had from AC factory for the High Clearance model with the single front wheel.Think they were a little narrower than yours but still 38",the WC high clearance
had 36" rears.
You are correct, but they look a lot different than these...these were used with the D series...also used by MF of that era.
Well I think they look pretty good / correct on there! Maybe a size narrower would be better, but then again, bigger is always better right??
Those look like taller rears. There was a high clearance option in the parts book I have that shows, I think, 38" rears but I am not sure without looking if those are that option.
Can have a new one if you want. Looks like it would be fun. Much warmer to plow snow with than what I'm currently using!
Knew of a guy that had a 3020 with mounted picker and that was a single. Biggest problem was sliding in the ruts. Sure was a surprise to me I think he switched after picking was done but he liked it because it wouldn't mud up.
(quoted from post at 22:06:39 11/20/16) Man, that thing is hideous lol
That is hideous! Single fronts are very rare here in NW PA. So rare every time I see one I still think they look kind of funny!
A single will turn shorter because it can turn farther without the tire hitting the frame because of the width of the assembly. This is on front mounted equipment, nothing mounted on front the same.
I was always told a single tire and tricycle are the same, If it had 2 tires its a narrow front end.(hint tri meaning 3). Not being picky but when I worked at the Deere dealer I had and old guy set me straight on that. Any way dad had an old farmall maybe a f12 or f20 single. He bought it from a neighbor and ended up trading it off for a hay rake I believe. Probably not safe on our hills.
Single front wheel tractors were much easier to steer than tractors with tri-cycle front ends when working with land that had been put up on a row. John Deere addressed the problem with their roll-o-matic system. Power steering pretty much solved the problem. Also, economics probably came into play back in the day. One wheel being cheaper to replace than two.
Yes they did because it worked better in the mud. My dad picked with a WD45 with a single front. The yoke was modified by adding a few inches of height to it to give a little more clearance between the yoke and tire. Our neighbor picked with a MM M670 with a single front wheel for the same reason.
(quoted from post at 10:54:43 11/20/16) No they didnt because of the wt of the picker single would not be the way to go for a mounted picker.
