Couple tractor questions
Nick167
On my 530 gas case tractor I just had the radiator record and now I put the tractor back together the engine seems to run as fast as it can the linking with is move free I even held the butterfly shut on the carb by hand what would cause this? And would having the radiator record cause the water pump to blow a seal as it seems that is leaking now?
Sounds like linkage is not hooked up correctly.
When things sit dry for some time things dry out and start to leak.
Common on fuel tanks, radiators, carburetors so could happen on a water pump seal.
Governor or throttle return spring not installed or not hooked to the proper spot?
Verify the throttle is returning to the point that the arm on the carburetor is resting on the idle speed adjustment screw.
