Where is Brake switch on Cub Cadet 14 hp mower
Satohbill
I have an older Cub Cadey with 14 hp Kohler engine that quit starting because the brake switch is worn out. Where can I find that brake switch or how can I bypass it.? I think it a model 1014 with driveshaft.
Goggle cub cadet parts. There is a site with the parts lists and breakdowns that will show you wherebit is, part number, price.
If it were me, I would start at the brake pedal and work my way back to the brakes to find the brake switch. It's got to be hanging there somewhere.
When you find it, unplug it. If the tractor starts, you've bypassed it. If the tractor doesn't start, try jumpering the two connections together with a short piece of wire and two crimp spade connectors. If the tractor still won't start, the brake switch was not the problem.
