My wife has an aluminum jog cart. The shafts are hollow and fit on to solid aluminum billet inserted into the aluminum tubular frame. These billets are held in place by two bolts and corrosion. The shafts fit over the billet and are secured by two bolts. Over time the aluminum corrodes and virtually welds the shafts and the billets together. I am having to replace the shafts. After removing the bolts, I tried everything I could think of to separate the shafts from the frame and finally had to cut them off. My question to you guys, is there some lubricant I can coat the billets and the inside of the shafts with that will keep the shafts and the billets from "welding" together over time? Will any grease work or is there a type of grease out there that works better with aluminum?
Thanks
Thanks
