Last tractor I got a couple days ago pictures
old
So saw another Case VAC listed on Craig's list and was only about 20 miles from me. It was locked up but 24 hours of ATF fixed that. Cylinders where dry so locked from sitting for a long time. Did not have the left hand rear tire on it when I got it but had a 11.2X28 laying around and put it on the rim today and then on the tractor. Not sure of the year since there is no serial number tag on the dash so need to figure out how to find that out. Steering rod is bent badly but think I have one or 2 of them laying around that I can use to replace it. Also back side covers are missing and I have a couple of them I will put on. Grill is not the best so I'll put on the best of the ones I have from the parts tractors. Also the distributor cap has been off of it for years to the distributor is badly rusted and I will probably have to get a used one for it. But I have pulled it off and dumped it out since it was full of water and then filled with ATF and that has helped a good bit. Front tires are shot and one front rim is bad but I also have other rims around to fit
Lost count a long time ago. I do how ever have 5 Case VAC/VAI tractors. 4 Farmall H 4 A/C Cs a D-17 the W speed Patrol and a couple A/C parts tractor and 2 Oliver' 1 Celtrac 3 JD tractor an 1 MM plus a few other like some MH ones Plus a few other Farmall's
I also did not say any thing about the road roller I have which I would call a tractor of sorts or the 950 Cat loader. There are if I did not miss one 7 Farmall on the place and 4 fords but as i said I have lost count. LOL Also forgot the MF 85
I think you have a corner on the market "so to speak" with Case VAs with Stockton hitches. Those 3pt hitches wern't that popular with all the linkages involved, but are becomeing very collectable in the Case World, either complete or as parts. Hitch parts alone should give you a good return on investment.
Loren
Geeze Larry, maybe you could paint some orange on some of your tools and join us, or at least look like a Fordson Major owner, if you can't handle the sudden change HeHe.
Loren
I'm just a tractor guy and not color blind when it comes to tractors. I do not care what brand they are I just care that they are old tractors
Most tractor I get I work on right on the trailer. So those jugs as you call them did not take the ride the tractor did. I'd say out of all the tractor I have had over the years 90% of them drove off under there own power. Not sure if this one will unless I either get a distributor or fix this one
Ya have a Ford 841S S stands for Sherman since it has the factory installed Sherman combo. Only truck I can maybe remember picking up with it would have been a Datsun years ago. Now cars on the other hand I have picked up a good many of them and even use it to more and pick up some of the tractors
Wife does not mind how many I bring home she knows it is an investment and over time does bring in $$. Plus one of these days I'll bring in one she likes and then she will claim it as her tractor but so far I have been lucky I have not found her, her tractor yet
