notjustair
The 55 Chevy 4400 had the engine out of a wrecked suburban put in it about 10 years ago. It's a 350 with a carb and no frills.
Yesterday I went to haul water and it wouldn't run. It started and died a couple of times and then nothing. It acted like the fuel pump. I took the lines apart and found there is fuel to the carb but the spark at the plugs is anemic and orange. I'm assuming it is something in the distributor. I'm familiar with the ignition module on Fords going out, but what goes on those older Chevys? It doesn't have computer stuff but does have electronic ignition.
It did this the other day and I walked away from it. I came back a while later and it fired right up and ran for a good hour after that. The switch continues to let power through so I am thinking it has to be in that distributor.
