Norm Wampler
New User
Hello,
I have a Massey Ferguson 135 with a Perkins 3 cylinder gas engine. Has always ran good until recently. For the last few months when I use it I have had to keep playing with the choke to get it to run good enough to be able to use it. Usually end up about 1/2 way out. I ran it out of gas the other day and when I got it started back up it was dumping gas up the air cleaner hose, through my air filter and on the ground. I called a parts place and they gave me their advice. So far I have rebuilt the carb, points, condenser, cap, rotor, plugs, and plug wires. Now it starts up and runs good for a little bit, then dies. I was told now I need a new coil. I also discovered the solenoid on the carburetor has a bare wire and is arching. Could this have been my problem all a long??? Does the solenoid need to be replaced??? Any help or advice would be greatly appreciated.
Thanks,
Norm
Thanks,
Norm
