Where oh where can I get a switch?
1946JDA
I have a 550 Oliver that is a good tractor except that the clutch safety switch is nearly junk. Can I get a direct replacement or do I have to make a different switch work? If I have to use a slightly different switch, what one? and will there need to be any wiring changes?
Not at the moment. I was doing good just to get the tractor back under a roof after it started giving me fits in the pitch black(of course).
If it's not available from Agco,call Jerry at Ag Parts First. He specializes in aftermarket parts for Olivers. Three three 0,two 64,sixty sixty.
You stated clutch switch, so if that being the situation, you can just place both wires on only one terminal and eliminate the safety function when starting. Choise is yours.
Loren
