antifreeze in oil 1945 farmall h
vinoking
New User
hi looking for some advice i have a 1945 farmall h that sat last winter and on first start up this spring was blowing antifreeze out exhaust i shut it right down and checked oil pan and it is full of antifreeze.looking for advice on where to start looking for the problem.thanks
pull the spark plugs and look for antifreeze---may have to pull the head and check that and the cylinder walls
drain the crankcase asap
My first thought is was the antifreeze as strong as it should have been and if not could it have frozen and cracked the block or head?? Now if it was good then head gasket is the most likely. As said pull the plugs out make sure not to mix them up or you may have fun getting the firing order correct again and spin it over and see if you get some antifreeze out of one or more cylinder. If you get it out of 2 that are side by side good chance the head gasket has gone between the cylinders
Does that have wet sleeves with oring seals at the bottom?
If so, drop the pan, look to see where the coolant is coming down from. If the sleeve seals are leaking, the head will have to come off anyway, but best to know where the leak is first!
