wilson ind
Got Cockshutt 40 diesel out. Been is shed for 14 months. Both 6 volt hd batteries shot. Just 5 years old. Just put 2 12 volts in
series to try as had previously had to grind and use starting fluid.Thing took of only 3 seconds. I do believe in this case 24 volts for very few
seconds is better than grinding with starting fluid. Do recall using 28 volt starting starting machine couple times when airplanes
had sat few days on line in zero degree winters. Never any problems with master switch off .
