O.T. Side by side fridge update
IA Roy
I looked at again this morning. I think the issue was that I put the fan on the shaft backwards. There is an open side and a closed side. Evidently I was trying to pull the air out of the ducting instead of pulling it out of the main cabinet of the freezer side. Time will tell. Now I will have to play with the thermostats again and will probably be freezing things in the refrigerator side. Thanks to all who took the time to share their knowledge. Roy
Mounting a fan blade on backward the air will still move the same way just not as fast or as much. Changing direction the motor turn will change direction
I think if the fan blade is put on the shaft backwards it will move the air in the wrong direction. Think about if you put the fan blade on an engine in a tractor or dozer it will blow the air from engine side out through the radiator. Bob
Wrong. In science class back 40 plus years ago it was proven when we did that test speed of air was slowed down but turn it back ward or forwards it still moves the same direction
(quoted from post at 15:25:08 09/21/16) Sorry, Old. I cannot agree with that. Bob
You could also take a piece of all thread and see if the same nut will thread on both ends.
Try it some time on a fan. But as I said air flow will be the same direction I know like I said we did it in science class back 40 plus years ago. But some people do not have open minds
On a ceiling fan you switch direction the fan turns to switch air flow from up to down. I you where to flip the blade on a ceiling fan and it will make little to no difference but then again there made to more air 2 ways but the common box fan made to air flow on way if you flip the fan it is not work near as well if on up side down
IA Roy says 'There is an open side and a closed side.'
To me that says he is working with a squirrel cage fan and not a simple fan blade.
Since it is closed on one side if it is turned the wrong way the correct stream of air can't be accessed to move it.
BTW: I agree with OLD - with a simple fan blade it does not matter which way it is mounted, the air always moves the same direction with a given shaft rotational direction.
