What is it called
Huk55
New User
I have an older Ford 4000 3cyl just below the oil filter there is a Hex head plug of some sort it leaks oil a little have been trying to find what it is called to get a replacement O ring I guess. Have had no luck chasing it down, Google search, Manuals...etc
Any ideas...Also looking for a gasket kit for the power steering pump has the older version its up front left side of engine straight forward of the oil filter.
Sounds like the oil filter drain plug. Remove it and see if it it truly an Oring,or a flat sealing ring. Then take that plug to
NAPA,or the nearest implement dealer(any color) and get a match.
It's a very large Allen wrench like a 3/4 I will have to go out and buy one I have a lot of tools but no Allen wrench that big...
Mark I have no idea what it is but that makes sense, If I remove the plug will anything pop out like a spring..?
(quoted from post at 07:44:32 09/18/16) It's a very large Allen wrench like a 3/4 I will have to go out and buy one I have a lot of tools but no Allen wrench that big...
Just use a bolt with a head that size....double nut the other end and use a socket on it.
When posting a message, scroll down a bit to small text, it says advanced posting tools, a little small link "upload photo"
Paul
Nothing will pop out, the plug just holds the gear down but the gear will not move as long as you don't turn the engine over with the plug out. Did you look at the link I posted?
Mark
