Asked about switching two 3ET batteries with one battery. Most recommendations were to switch to one group 31 battery. Found one with slightly over 1000 cold cranking amps at Theisens Farm Store for about $90. Was able to eliminate the short jumper cables putting the two 12 volts in parallel. Seemed like one battery would fail causing both to be basically be shot since you had to replace them in pairs. Very happy with the change. The only thing I have left to do is modify the hold down straps. To the credit of the batteries I took out -they were John Deere Strong Box batteries and the date on the ends was 2006. They lasted a good long time.
