IHC 450 fast hitch
myron 101
New User
How do get the fast hitch to work on my ihc 450.It has three hydraulic levers so must have three valves. It had a 4 hose loader on it that I took off but fast hitch won't work.
thanks Myron101
The three valves on my400 control
A vertical cylinder mounted to the frame and the fast hitch arms.
A horizontal cylinder below the brake pedals which controls a pivot at the front of the fast hitch frame.This cylinder may be locked in place by a
pin or bolt
The third lever leads to connectors for a remote cylinder.
If none are working, make sure you have fluid up to the full mark in the reservoir
On your tractor there is a traction control in place of the front cylinder discussed before. The hitch should be the hitch up and down. The other two should be
for remotes. If the selector "knobs" on the valves are not in D or S positions, they can fail to work. I also agree on checking the level. Jim
