Trying to get my 4020 back up and going after sitting in the barn for 7 years. Wasn't getting any fuel past the injector so i took it off and took it to the diesel shop. Got it back on and timed but am still not getting fuel past it.
I used the priming hand pump, filled the filters, and pumped until it wouldn't pump any more (with banjo fittings loose). Turned it over a couple times, but didn't have any fuel coming out of the fitting. I took one bolt entirely off to see if anything was happening and it looked like there was a little fuel that was bubbling out with air.
I'm pretty sure the injector has fuel in it because when i loosen the inspection plate, fuel starts coming out. I loosened the 'out' bolt and fuel started coming out.
I don't understand why I don't have fuel spraying out.
Any help would be great.
-Bryson
-Bryson
