tomstractorsandtoys
I need a beam for in my shop to use for a hoist. It will need to span 32 feet and should be capable of handling 4000 pounds. I was thinking of a 12 inch I beam but found this instead. It is a 10x10 H beam with a 3/4 inch thick top and bottom flange. It is half the price of any I beams I found.It is used. Is there any reason you can think of why it will not work? I think it should be heavy enough or maybe someone thinks not? I will need a different trolley and my local welding shop said he could build that if I supply the wheels. Where would you find trolley wheels for a H beam.Any thoughts or ideas? Thanks Tom
