Fred Werring
Rolling up some hay, the clip came loose that was supposed to hold a steel hydraulic line away from the PTO on the baler. (855 NH) Rubbed a hole in the line.
So can I use 3/8 brake line as a replacement? I would think it should handle the pressure, but I don't know.
Anybody been there/ done that?
Maybe if the hole's small enough (haven't looked yet, letting things drip dry and cool off) a compression coupling would work...they used compression ferrules on the ends of the steel line from the factory.
Thanks
Fred
Thanks
Fred
