Tractor talk
Kennybob
New User
Maybe some body can help me on here , I have an old ford that I'm not for sure of the model number an year, this set of numbers I found under the battery box # 21201D, an this set of numbers are from the engine block# 6015H, thanks for any an all help
21201D
2 2000 with 134 ci gasoline or 144 ci diesel engine
1 This number narrows down the year built between 1962 and 1965
20 Utility-type Ag tractor
1 Four speed trans with PTO
D diesel engine
If you look in the same spot just under this number you should see another number.
This number will tell us when it was built.
